DIYnot
Local | Network
   DIYnot > Forums
Local | Network
reducing water pressure in worcester bosch combi boiler
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
humey53
from United Kingdom
PostPosted: Sat Mar 26, 2011 8:39 pm Reply with quote
Visited my mum today and noticed the pressure dial on her Worcester Bosch boiler was reading 3.5 bar, which seems higher than I thought was recommended. I happen to have the same boiler, so am interested to know
1 how do you reduce the pressure (I know how to increase it)?
2 Does it incurr any damage running at this higher pressure?
3 Isn't 1 bar the correct pressure?
Back to top
 Alert Moderators
powerflushingpro
from United Kingdom
PostPosted: Sat Mar 26, 2011 8:57 pm Reply with quote
It's not good. Make sure the filling loop is shut, then bleed a radiator to reduce the pressure it will take a while to get it to between 1-1.5bar. If the pressure goes back up you need a professional to have a look at it.
Back to top
 Alert Moderators
Bankrupt
from United Kingdom
Thanked: 16 times
PostPosted: Sat Mar 26, 2011 11:26 pm Reply with quote
Certainly too high - Is it reading 3.5 Bar with the pump running or not running ? Is the key removed from the filling loop ? - If not you may have pressurisation from the mains water supply via the filling loop.
Back to top
 Alert Moderators
hansthebear
from United Kingdom
Thanked: 62 times
PostPosted: Sun Mar 27, 2011 12:25 am Reply with quote
points to a faulty pressure relief valve also
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2181 times
PostPosted: Sun Mar 27, 2011 10:56 am Reply with quote
When was the last time the boiler had a full service?
Back to top
 Alert Moderators
Bankrupt
from United Kingdom
Thanked: 16 times
PostPosted: Sun Mar 27, 2011 6:10 pm Reply with quote
Why would lack of servicing cause the pressure to be too high ? . icon_confused.gif
Are you suggesting that lack of inhibitor could be causing corrosion and the hydrogen formed is increasing the pressure ?
Back to top
 Alert Moderators
rgas
from United Kingdom
Thanked: 4 times
PostPosted: Sun Mar 27, 2011 9:13 pm Reply with quote
Likely to be the expansion vessel or loop left on, turn the heating off and let the system cool, does the pressure drop? If so its your vessel, if not and theres a constant drip from the blowoff, its your loop or possibally the heat exchanger split depending what type it is. Ive never had hydrogen causing problems with pressure, would normally release itself through the auto air vent. He was asking about servicing as we normally check expansion when we service it.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
water pressure/combi boiler/pressure reducing valve......... 3 10940 Fri Nov 09, 2007 12:29 pm
pressure reducing valve fitted but still got water hammer 11 160 Thu Sep 15, 2011 11:35 am
Reducing hot water pressure HELP 4 340 Sun Jan 14, 2007 7:58 pm
pressure reducing valve - stopping water hammer ? 5 2581 Mon Mar 31, 2008 8:32 pm
Reducing cold water pressure for mixer tap shower 10 3120 Tue Feb 17, 2009 12:31 am
DIYnot
