I have a Bosch Worcester System Boiler with two motorised valves for the water and heating zones.
Currently my boiler pump runs all the time when the programmer turns on the hot water zone even when the water is hot enough. This is because the motorised valve switch makes the circuit for the Switched Live back to the boiler and the boiler pump runs all the time with the Switched Live high.
I was thinking whether I can put a Cylinder thermostat in series with the Switched Live so that the Live is dropped to zero when the hot water is up to temp? Is this ok or should it not switch mains voltage. If not how else could I do it? Help greatfully received.
