DIYnot
Local | Network
   DIYnot > Forums
Local | Network
baxi bermuda not firing
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
tonyb70
from United Kingdom
PostPosted: Sat Apr 02, 2011 8:49 am Reply with quote
hello,due to having 3 engineers out to look at my problem boiler,it is still not working,
i have a baxi bermuda 50/5 inset
the problem is it will not ignite,the red light is on at the front,and an amber light behind,flashes about every 5 seconds,
occasionally it will kick in and work fine,but usually not working,
engineer one said it was the pcb board,which was already changed about 2 months ago.
enginneer 2 came to fit board,but after pulling it all apart,seems to thonk it was something else,he tried board and got the same problem,he went and turned the pump up tp 3 and seemed to think it was a s ticky pump,
all worked fine for a few hours then it stopped again
engineer 3 came and instaled new pump,all worked well for a couple of hours,now its stopped again,
it has just started for 20 seconds and cut out,
any ideas anyone,?
regards tony
Back to top
 Alert Moderators
misterdubya
from United Kingdom
Thanked: 367 times
PostPosted: Sat Apr 02, 2011 8:55 am Reply with quote
You will need to employ an RGI to inspect or replace either the oxypilot assy or the thermister.
Mr. W.
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Sat Apr 02, 2011 8:57 am Reply with quote
3 different companies that can not solve the problem?
What is the history of the boiler?
Back to top
 Alert Moderators
tonyb70
from United Kingdom
PostPosted: Sat Apr 02, 2011 9:02 am Reply with quote
i wasnt expexting such a quick reply,
its the same company,but 3 diferent engineers,
the boiler is 7 years old,we have it serviced regulary to,
ive turned it all off,put the controls now calling for heat,lit the fire,now the boiler has kicked in,but not for long i bet,
Back to top
 Alert Moderators
tonyb70
from United Kingdom
spoke to soon
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Sat Apr 02, 2011 9:18 am Reply with quote
Any faults/problems before?
Did those services include actually stripping and cleaning the boiler? How long do they take to do a service?
Is it the same company that installed it?
Back to top
 Alert Moderators
tonyb70
from United Kingdom
PostPosted: Sat Apr 02, 2011 9:25 am Reply with quote
the only problem weve had was the pcb board changed a couple of months ago,but an engineer came and tried a new board the other day,and said that it wasnt that,
the sercice is usually about an hour,and it has been fully stripped and cleaned and tested
no its a different company that came to service it,as the company that fitted it initially wired it up wrong,which was spotted by an engineer that came to service it,so i dont have much faith in the installation company,
in the last 30 mins ive been sat here,its started about 5 times,but cut out after 20- 30 seconds
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Sat Apr 02, 2011 9:28 am Reply with quote
What does this mean according to the M.I.?
Back to top
 Alert Moderators
tonyb70
from United Kingdom
PostPosted: Sat Apr 02, 2011 9:36 am Reply with quote
ihavnt got instructions for the boiler,they didnt leave me any,
but an engineer went onto a faultfinding baxi site and it said pcb,if the red light was on,but didnt mention a flashing amber light
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Sat Apr 02, 2011 9:49 am Reply with quote
Maybe it's and idea to get the M.I. if only to know what to do when certain lights come on.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Baxi Bermuda 551 not firing 4 420 Sat Oct 06, 2007 12:03 am
Baxi Bermuda SP2 back boiler not firing up 3 1080 Wed Sep 23, 2009 5:21 pm
Baxi Bermuda not Firing (another one!) 4 480 Fri Apr 06, 2007 6:03 pm
PLEASE HELP WITH BAXI BERMUDA INSET 2 50/4 not firing up!!! 25 2320 Mon Jun 15, 2009 7:37 am
Baxi Bermuda Inset 2 not fully firing 3 620 Wed Dec 10, 2008 11:37 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
