DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Toilet does not stop flushing
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Workshopshed
from United Kingdom
PostPosted: Mon Apr 04, 2011 9:31 am Reply with quote
Had a toilet put in back in October last year and we've got a new problem just started occuring this week.
It's one of those new types where there are 2 buttons for short and long flush. The problem is that after flushing it does not stop and continues draining into the loo, the button goes all floppy at this point.
Internally it seems a bit flashy, the button connects to a pipe via an unclipable connector and then down in the bottom of the loo there's a large plastic box with the following label on the top.
www.lab-sanitary.com
That website errors for anything other than the front page.
The ballcock mechanism also seems a bit high tech but that does appear to work ok. If you stop the water flowing in, that stops the water flowing on into the toilet and then it seems to work again for a while.
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 873 times
PostPosted: Mon Apr 04, 2011 10:51 am Reply with quote
then it`s the high tech float valve letting by icon_idea.gif and the water is running down the internal overflow - that`s where you need to look icon_wink.gif
Back to top
 Alert Moderators
Workshopshed
from United Kingdom
PostPosted: Mon Apr 04, 2011 11:31 am Reply with quote
Thanks Nigel, I checked that, the problem appears to kind of be the opposite. The problem is occuring when the level is right at the bottom of the cistern. It's like the valve that tells it to stop is sticking
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Mon Apr 04, 2011 12:00 pm Reply with quote
what model number is it you have ?
When you say the button connect via a pipe do you mean the blue cable ?
these are prone to sticking and holding the flush valve opn.
Back to top
 Alert Moderators
Workshopshed
from United Kingdom
PostPosted: Mon Apr 04, 2011 4:41 pm Reply with quote
Ah yes, I see its a cable, there's no kinks or anything obviously restricting motion
Back to top
 Alert Moderators
mannotaboutthehouse
from United Kingdom
PostPosted: Sun Nov 10, 2013 3:12 pm Reply with quote
I have the exact same problem, been like this for a while now and sometimes after flushing the water block mechanism goes down on its own or having to fiddle with the button a few times, or placing your hand into the cistern to give it a gentle nudge....don't know whether this is caused by something in the water making it stick or what?
However, have another problem to add to this, the device that fills the cistern up with water now is deciding to not allow it to fill. Either it drips dead slow to take hours to fill up or not at all....tried cleaning any dirt or scum but still no luck...
Typical, a chinese model too?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
My mother's toilet...Flushing problem 6 80 Fri Mar 08, 2013 3:47 pm
Twyfords toilet not flushing 8 840 Thu Jul 08, 2010 8:53 am
Toilet flushing problem 5 100 Wed Aug 28, 2013 12:02 am
Toilet upstairs flushing but not pulling contents down 8 3800 Wed Jun 21, 2006 12:58 pm
Noise when flushing toilet 4 160 Tue Oct 12, 2010 7:04 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
