Cleaning existing system for new boiler
20 Feb 2011
Bristol
Can you open the filling loop with a hose connected to a drain off to remove sludge ect? i am replacing a boiler tommorow as the old one has totaly gave up (yes i am gas safe) i can't afford a powerflush as i am just starting up and am unable to put cleaner into the old system as the boiler is not working. any advice greatly apriciated.
Thanks, will try that, I don't think it's paticularly dirty or anything just want to make sure no crap gets to the new boiler. i'm fitting a magna clean as well so should be ok. If the pump has had it though surley filling loop open and hose connected should shift i?. Close all but one rad and tap the same as a power flush.
Your method will shift nothing and would be a waste of water. If you've any sludge it needs to be dissolved with chemicals as advised.
In no way can I support your ideas that you should do a shoddy job because you are "starting up".
Thats the classic way to get a bad reputation, win enemies and lose customers.
The customer pays for the installation and the installer should be doing the job properly.
Whats the point in doing anything badly?
Worse it adds to the evidence of cowboy plumbers and the already bad reputation of this trade which I have to endure whenever anyone learns of what I do.
Why not join the cc and at least keep your bad practices away from public gaze?
How can you say this? , you charge by your own addmission under £1900 to fit a new boiler , i can guarantee you cannot flush the system properly when charging this amount for the job..........................Gas Safe are looking to recruit a number GCOs , have you applied?
cc = combustion chamber our private den
magna clean to help flush manualy flush rads outside tap
and cleans agent
