turbomax plus thermocompact (non condensing) and ecomax (condensing)
Ignition lockout, check gas supply or igntion sequence for when it locks out can you hear inition gas valve opening burner lighting.
i f the boiler is the turbo max plus the the F28 fault code is;
Boiler goes to lock out
No gas
Insufficient gas
Incorrect gas valve adjustment
Electrode defective
Ignition lead defective
Electronic igniter defective
