Can PVA be applied by Spray Gun???
13 Apr 2011
Renfrewshire
Hello Guys
Just as the title says, Can it be applied by spray gun, or some sort or inexpensive spray pump???
For sealing interior brickwork!
Thank You
You could use one of the napsack sprays the gardners use no problem. Would have to clean it out thoroughly so as not to get it blocked up.
absolutly brilliant mate, redherring was saying much the same, great info guys, really really appreciatte it.
Are you talking about the ronseel type 5 litre ones about £20 etc Robbie?
The napsack ones are the ones that strap to your back, but you can use the smaller ones just the same. I used to use them for spraying thompsons water seal onto brickwork on older houses.
