| Author |
Message |
wcavanagh
Joined: 14 May 2009 Posts: 307 Location: Dundee, United Kingdom Thanked: 2 times
Posted: Sun Jun 12, 2011 8:27 pm |
I have had a few quotes for installing a combi and 8 rads into my new house. Some are using all copper pipes, others are using copper in visible places, and plastic under floors.
Is it normal to use plastic on central heating now?
Cheers |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
onlyfitidealboilers
Joined: 11 Jan 2010 Posts: 1594 Location: Aberdeen, United Kingdom Thanked: 98 times
Posted: Sun Jun 12, 2011 8:34 pm |
have you seen the price of copper !! |
| Back to top |
wcavanagh
Posted: Sun Jun 12, 2011 8:39 pm |
Hehe, yep.
Is the cost the main reason? |
| Back to top |
mysteryman
Joined: 05 Jun 2010 Posts: 1666 Location: Shropshire, United Kingdom Thanked: 233 times
Posted: Sun Jun 12, 2011 9:05 pm |
No, it is better in many ways - done properly. |
| Back to top |
wcavanagh
Posted: Mon Jun 13, 2011 7:16 am |
So I am better going for a quote with all copper?
Cheers |
| Back to top |
Mark Br
Joined: 17 Oct 2007 Posts: 782 Location: Berkshire, United Kingdom Thanked: 109 times
Posted: Mon Jun 13, 2011 2:42 pm |
As a plumber I was always taught that it had to be copper and that plastic was for cowboys and diy'ers. However, having used plastic and so far have had no problems with it all my previous prejudices of plastic pipe have gone. Copper should still be used where you can see it (plastic fittings are ugly), but plastic used properly underfloors, etc will speed up the installation process and reduce costs with no effect on the performance. |
| Back to top |
wcavanagh
Posted: Mon Jun 13, 2011 2:46 pm |
| Mark Br wrote: | | As a plumber I was always taught that it had to be copper and that plastic was for cowboys and diy'ers. However, having used plastic and so far have had no problems with it all my previous prejudices of plastic pipe have gone. Copper should still be used where you can see it (plastic fittings are ugly), but plastic used properly underfloors, etc will speed up the installation process and reduce costs with no effect on the performance. |
Thank you. Very interesting. There is a fair amount of price difference between the part copper installs and all copper installs.
Cheers,
Will |
| Back to top |
PlumbGas
Joined: 26 Feb 2011 Posts: 398 Location: Surrey, United Kingdom Thanked: 57 times
Posted: Mon Jun 13, 2011 4:07 pm |
| wcavanagh wrote: | | Mark Br wrote: | | As a plumber I was always taught that it had to be copper and that plastic was for cowboys and diy'ers. However, having used plastic and so far have had no problems with it all my previous prejudices of plastic pipe have gone. Copper should still be used where you can see it (plastic fittings are ugly), but plastic used properly underfloors, etc will speed up the installation process and reduce costs with no effect on the performance. |
Cheers,
Will |
Just keep in mind it's not the price of the material that counts, it's the quality of the installer, choose carefully, as already stated plastic works ok if it's installed correctly, often it isn't |
| Back to top |
wcavanagh
Posted: Mon Jun 13, 2011 4:10 pm |
What a nightmare
Prices vary a lot |
| Back to top |
Mark Br
Posted: Mon Jun 13, 2011 4:52 pm |
Very good advice from Plumbgas. Go with an installer that has been recommended and not just the one that comes in with the cheapest quote |
| Back to top |
wcavanagh
Posted: Mon Jun 13, 2011 4:54 pm |
| Mark Br wrote: | | Very good advice from Plumbgas. Go with an installer that has been recommended and not just the one that comes in with the cheapest quote |
I never said im going with cheapest. I have 6 quotes and they range from very cheap to very expensive... |
| Back to top |
wcavanagh
Posted: Mon Jun 13, 2011 5:01 pm |
| wcavanagh wrote: | | Mark Br wrote: | | Very good advice from Plumbgas. Go with an installer that has been recommended and not just the one that comes in with the cheapest quote |
Just thought that sounds really rude, sorry, hehe.
I am new to the area so hard to get recommendations. |
| Back to top |
Mark Br
Posted: Mon Jun 13, 2011 5:24 pm |
Don't worry I don't offend easily
I'm not sure if it covers your area of Berkshire, but there is a directory called the Green Book (think it's also online), to get in the directory the company would need to be recommended by customers; might be worth checking if any of the companies quoting are in that.
Getting 6 companies to quote is a lot - what prices have you been given |
| Back to top |
wcavanagh
Posted: Mon Jun 13, 2011 5:28 pm |
| Mark Br wrote: | Don't worry I don't offend easily
I used a website with customer reviews and posted the job. I am moving to Kettering so 100 miles north of Berkshire.
Quotes range from £2400 to £7000 |
| Back to top |
PlumbGas
Posted: Mon Jun 13, 2011 5:33 pm |
| wcavanagh wrote: | | Mark Br wrote: | Don't worry I don't offend easily
£7 is well high, Were abouts in Berkshire are you based then ?, and which boilers are you looking at ? |
| Back to top |
