Hi -
I realise that the above may have been covered [separately] before but was wondering if there is a single solution that I can use to resolve both problems.
I am about to redecorate the bedroom and prefer to use matt instead of the silk currently on it. There are also blob shaped stains wherever there is a fixing.
I have read about using a 'Soft Sheen' Emulsion as a primer/undercoat before the Matt finish coat but fear this will not blot out the marks caused by the Plasterboard fixings (galvanised nails). I am wondering whether to use an all purpose oil based primer instead? I have used 100 grit sand paper to provide a key but want to be sure I am going about it the right way before I start painting.
The room is part of an extension built about 8 years ago.
