DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Tiling around a wood burner
Post new topic   Reply to topic    DIYnot.com Forum Index > Tiling
Author Message
DIYgirlie
from United Kingdom
PostPosted: Fri Jun 24, 2011 11:15 am Reply with quote
I have a small fireplace in my lounge and I plan to put in a wood burner. I would like to tile the inside of the fireplace. I have seen a couple of websites which sell unglazed Victorian tiles for this purpose, but I was wondering whether I have to buy these tiles, or whether other (more common) types of tiles could be used instead? I don't want to use quarry tiles. Many thanks for your help! icon_biggrin.gif
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Fri Jun 24, 2011 5:24 pm Reply with quote
As this comes up so often, Iíve put together this generic post; read the links but not all of them may apply to you.
You can DIY a stove install but you need to understand the Building Regs. (which changed in October 2010), submit a Building Notice & pay a fee. Your LABC will inspect &, assuming everything is OK, issue a compliance certificate; the BI may want to witness smoke & spillage tests. No compliance certificate may lead to difficulties when you come to sell your property; if cannot produce a compliance certificate in the event of a problem, your insurance company may invalidate your policy & reject any claim.
Lots of archive threads on this, & other things you have to watch out for, here a few links for you to read:
http://www.stovesonline.co.uk/stove_building_regulations.html
http://www.hetas.co.uk/public/certificates.html
http://www.solidfuel.co.uk/pdfs/buidling_regs_consumer%20leaflet.pdf
http://www.diynot.com/forums/viewtopic.php?t=183614
http://www.diynot.com/forums/viewtopic.php?t=211524
http://www.diynot.com/forums/viewtopic.php?t=242738
http://www.diynot.com/forums/viewtopic.php?t=224751
& some more sobering stories just in case you think the safety thing is just a load of old tosh:
http://www.solidfuel.co.uk/main_pages/news.htm
http://www.dailymail.co.uk/news/article-1273882/Teenager-dies-summerhouse-wood-burning-stove-leaks-carbon-monoxide.html
http://www.eveningnews24.co.uk/news/warning_over_heaters_after_norfolk_couple_s_death_1_811099
Also get at least 3 quotes from local independent HETAS installers:
http://www.hetas.co.uk/nearest_member
You might be pleasantly surprised & you should ask yourself if you really want all the hassle & risk getting it wrong; climbing onto the roof with an 8M stainless steel snake on your back is not for the feint hearted!
__________________
Read more: http://www.diynot.com/forums/viewtopic.php?t=267604&highlight=#ixzz1I6jlicut
With regard to the tiles, most ceramic or porcelain tiles will be OK, stone even better; personally I like black granite but it can be expensive. Regards tiling, you must have the right background & select the correct adhesive which is definitely not tub ready mix; you need something that will withstand around 150 degrees C. As you will read from the above links, do not use plaster or plasterboard to finish inside the fire opening or on the chimney breast within 300mm to the side or at least 500mm above the stove, it will fail & your tiles will fall off.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Tiling All times are GMT
Page 1 of 1
Jump to:
Wood burner, backing plate or tiles? 5 820 Thu Sep 13, 2012 1:58 pm
Bath room shower tiling on wood 2 80 Fri Oct 04, 2013 8:51 am
tiling on existing wood floor 7 1280 Wed Sep 26, 2007 4:39 pm
how to seal a damp wood floor before vinyl tiling? 3 80 Fri Jul 06, 2012 5:10 pm
Tiling onto wood? 3 6320 Tue Nov 13, 2007 10:05 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
