| Author |
Message |
Corky74
Joined: 17 May 2011 Posts: 20 Location: Yorkshire, United Kingdom
Posted: Wed Jul 06, 2011 10:16 pm |
Last time I bought an oven from ikea it came with a plug many years ago. The new oven I've now bought doesn't it's a framtid ov9 max power 2.725kw what's the way to go with the installation of is one |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
securespark
Joined: 11 Jan 2004 Posts: 22665 Location: Cheshire, United Kingdom Thanked: 317 times
Posted: Wed Jul 06, 2011 10:22 pm |
What do the installation instructions say? |
| Back to top |
ban-all-sheds
Joined: 27 Aug 2003 Posts: 41748 Location: London, United Kingdom Thanked: 1357 times
Posted: Wed Jul 06, 2011 10:31 pm |
blah blah blah if in doubt consult a qualified electrician blah blah blah?
Corky - what do you have available to connect the oven to? |
| Back to top |
Corky74
Posted: Wed Jul 06, 2011 11:02 pm |
| ban-all-sheds wrote: | blah blah blah if in doubt consult a qualified electrician blah blah blah?
Now the sparky has sorted out my induction hob I'm just left with the ring main for the kitchen appliances instructions. |
| Back to top |
ban-all-sheds
Posted: Thu Jul 07, 2011 12:07 am |
What circuit did he put in for the hob? Breaker rating, cable size?
Is the hob connected to a cooker outlet plate?
Is the hob near the oven?
Your best bet could well be to replace the outlet plate with a twin one,
in one half of a dual box, and an FCU for the oven in the other side. The replacement outlet plate supplies the hob and the FCU. |
| Back to top |
mongy1
Joined: 28 Sep 2007 Posts: 34 Location: Cumbria, United Kingdom Thanked: 1 time
Posted: Thu Jul 07, 2011 12:28 am |
I have a similar oven from Ikea, they are made by Whirlpool.
I had to phone the Ikea help line to find out that it was 2.4Kw & 13 amp as the instructions & website lack this information.
Phone them & check.
My installation is 6mm2 cable from consumer unit to cooker switch, 6mm2 T&E from cooker switch to cooker outlet plate for hob (hob wired from outlet plate with 4mm2 HO5 RR-F flex, recommended on the Whirlpool site for their 13 amp ovens but a s** to find).
Spur from cooker switch to 13 amp neon fused control unit using 2.5mm2 T&E then 2.5mm2 T&E to flex outlet plate for the oven, then FO to oven using the 1.5mm2 flex supplied with the oven.
Will check what rating MCB my electrician used at the CU and update.
Obviously your requirements will be different to others.
If unsure, consult a registered electrician. |
| Back to top |
mongy1
Posted: Thu Jul 07, 2011 12:43 am |
Also be aware that your hob will draw more than the oven. 2 rings at full tilt will draw more! |
| Back to top |
Corky74
Posted: Thu Jul 07, 2011 8:21 am |
| ban-all-sheds wrote: | What circuit did he put in for the hob? Breaker rating, cable size?
The hob is on it's own 32amp mcb 6mm cable wired into a single outlet plate,the hob is above the oven |
| Back to top |
ban-all-sheds
Posted: Thu Jul 07, 2011 10:10 am |
Replace the outlet plate with a twin one in one half of a dual box, supplying the hob and an FCU for the oven in the other side. |
| Back to top |
