DIYnot
Local | Network
   DIYnot > Forums
Local | Network
What is the tightness test pressure fora medium pressureTEST
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
joeread
from United Kingdom
PostPosted: Fri Jul 08, 2011 7:50 am Reply with quote
Back to top
 Alert Moderators
adlplumbing
from United Kingdom
Thanked: 312 times
PostPosted: Fri Jul 08, 2011 7:57 am Reply with quote
read your books it is their
it also help you learn
and once you passed it chance are you never need it again as never seen one yet outside a class room
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Fri Jul 08, 2011 10:40 am Reply with quote
edit . apologises for wrong answer earlier you test at 19mbar on some and 20 on others depndant on how it is configured.
Lots of new estates out there with it
Back to top
 Alert Moderators
numpty1
from United Kingdom
Thanked: 324 times
PostPosted: Fri Jul 08, 2011 3:48 pm Reply with quote
A little knowledge can be dangerous,have not seen a cubic ft dial in at least ten years nor worked on low pressure reg for the same amount but i still have to know how to test and rate them,its known as competence
Back to top
 Alert Moderators
adlplumbing
from United Kingdom
Thanked: 312 times
PostPosted: Fri Jul 08, 2011 6:27 pm Reply with quote
yes or you can look it up when you need to know
or ring a freind
Back to top
 Alert Moderators
Boilerman2
from United Kingdom
Thanked: 962 times
PostPosted: Fri Jul 08, 2011 6:34 pm Reply with quote
What do you mean by "Medium Pressure"???? if OP is more than 75Mb
you will need to test to IGE UP1 which is far and beyond a Domestic UP1/B test and will require the services of one or more operatives with the relevent qualifications!! icon_wink.gif
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Fri Jul 08, 2011 7:49 pm Reply with quote
I take it he is on about standard domestic meter set up and that is nothing special
Back to top
 Alert Moderators
petit_pablo
from United Kingdom
Thanked: 1289 times
PostPosted: Fri Jul 08, 2011 8:11 pm Reply with quote
Medium pressure is in scope for CCN1. Not a problem testing and purging it on domestic ticket.
Back to top
 Alert Moderators
monoxide62
from United Kingdom
Thanked: 102 times
PostPosted: Fri Jul 08, 2011 10:40 pm Reply with quote
Maybe a bit confusing to some , gas service pipe up to medium pressue regulator will be 2 bar pressure as opposed to 75mb , tightness test is carried out @ 19mb.
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 322 times
PostPosted: Sat Jul 09, 2011 12:47 am Reply with quote
Not in CCN1 any more.
A meter inlet valve should now be fitted after the governor to test installation.
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Sat Jul 09, 2011 1:07 am Reply with quote
monoxide .read the pages in the book before it mentions19 mb
Back to top
 Alert Moderators
monoxide62
from United Kingdom
Thanked: 102 times
PostPosted: Sat Jul 09, 2011 1:54 am Reply with quote
What book are you refering too? , 5th edition-revised?
TT without MIV........ Let-by @ zero mb , TT 19mb.
TT with MIV.....Let-by @ 10mb , TT 20mb.
No MIV = NCS.
Does your refference material suggest otherwise?
Thanks.
Back to top
 Alert Moderators
petit_pablo
from United Kingdom
Thanked: 1289 times
PostPosted: Sat Jul 09, 2011 6:48 am Reply with quote
Thats a bonus, i am due to do acs end of this year. Thats one less thing to worry about then!
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Sat Jul 09, 2011 8:21 am Reply with quote
Petite.
There is only 1 question on medium pressure and its a really basic one, think it was double ecv.
Monoxide yep its one of those trick questions where if asked it would be easy to answer either 19 or 20 but then have to explain what pressure is used and when.
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Sat Jul 09, 2011 10:25 am Reply with quote
Why don't you read your books in stead of asking silly questions here? All you need to know for you exam is in there.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Medium Pressure Gas Meter - Bodged Installation 4 1040 Thu Feb 09, 2012 9:29 am
recommendations fora corgi bod to fix my boiler in tottenham 5 480 Tue Aug 22, 2006 4:25 pm
reinstated fire - tightness test before????? 14 580 Mon Nov 22, 2010 10:22 am
Still smell gas after tightness test 15 1380 Tue Jul 05, 2005 3:07 pm
Tightness test 14 1020 Sat Mar 10, 2007 2:50 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
