DIYnot
Local | Network
   DIYnot > Forums
Local | Network
how to remove a geberit impuls dual flush unit from cistern?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
minco
from United Kingdom
PostPosted: Sun Jul 10, 2011 12:51 pm Reply with quote
this images says it all:
I have to remove a geberit impuls dual flush unit, as it has a leak, which causes the inlet valve to run all the time.
The problem is, the cistern is too narrow to unscrew the base. Is there a way to remove the J-shaped pipe?
Back to top
 Alert Moderators
tomy
from United Kingdom
Thanked: 14 times
PostPosted: Sun Jul 10, 2011 1:14 pm Reply with quote
Take the cistern off from the pan then unscrew the big nut on the underneath that you cant see at the moment .
Back to top
 Alert Moderators
minco
from United Kingdom
PostPosted: Sun Jul 10, 2011 1:35 pm Reply with quote
Thanks, but the screws for cistern are not really accessible from the bottom (a magnificently crappy job was done, whoever did it).
All I want to do is to avoid the leak, is there an easier way of doing this?
Back to top
 Alert Moderators
minco
from United Kingdom
PostPosted: Sun Jul 10, 2011 2:31 pm Reply with quote
tuned out to be this 'bubble' problem from the outlet seal:
http://www.diynot.com/forums/viewtopic.php?t=166017
so I don't have to remove the base.
if you find this by google, do not buy geberit dual flush. it is a magnificent failure.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Geberit dual flush valve leak 32 62920 Thu Jan 29, 2009 1:47 pm
Geberit flush pipe leak 2 40 Mon May 14, 2012 7:46 am
Geberit flush plate 2 80 Mon Jan 17, 2011 9:58 am
Geberit Flush Plates 2 180 Mon Oct 04, 2010 7:04 pm
Geberit toilet flush 2 1800 Sat Feb 10, 2007 11:52 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
