k_90
Joined: 10 Jul 2005 Posts: 2 Location: Glasgow, United Kingdom Thanked: 0 times
Posted: Sun Jul 10, 2005 9:57 pm Post Subject: diy sos ceramic tiles on bathroom |
hi I have just removed my bathroom tiles (2 rows) however I also managed to pull off most of the plasterboard as well,including a rather large hole! Should I add plaster or renew the plaster board? what should I be doing? Thanks for any advice !![/list] |
slippyr4
Joined: 12 Jul 2005 Posts: 681 Location: Bedfordshire, United Kingdom Thanked: 0 times
Posted: Tue Jul 12, 2005 1:27 pm Post Subject: |
I'd patch plaster it. you don't have to be good at it if you're tiling over the top. if the hole is big then stick a piece of cardboard in it to block it up so the plaster can stick to something |
k_90
Posted: Thu Jul 14, 2005 8:03 pm Post Subject: |
I bought i bag of gypsum plaster. does anyone know the right consistency to apply it? What happens when it starts to crack is this normal ie drying out?
thanks in advance |
jbonding
Joined: 04 Feb 2005 Posts: 1926 Location: Manchester, United Kingdom Thanked: 0 times
Posted: Thu Jul 14, 2005 9:46 pm Post Subject: |
cut the board back to the stud and replace theres no need to involve plaster if your tiling over. |
waltone
Joined: 14 Nov 2004 Posts: 18 Location: United Kingdom Thanked: 0 times
Posted: Fri Jul 22, 2005 10:45 am Post Subject: |
The cracking is due to the water being sucked out before it has time to set. To slow this down, give the wall that you are going to plaster, 1 or 2 coats of watered down PVA, let the fist one dry then apply the second coat of PVA and then plaster over. That should slow down the drying speed.
Walt  |
