DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Kitchem wiring with cooker point - diagram please :)
Author Message
danyboy
from United Kingdom
PostPosted: Wed Aug 17, 2011 9:28 pm Reply with quote
hi all
i am new and i hope u dont kill me for my maybe noob question icon_smile.gif OK i got job for wiring kitchen. Socket its not the problem, standard ring 2,5mm, light radial 1,5mm, but cooker this is my problem.... i know must be wiring via 6mm cable, but now i have two gap in wall, one for Coocker Control Unit, but other one ?? how i can connect everything ?? i realy need some diagram, i find some website http://www.ultimatehandyman.co.uk/diy_electrics_cooker_circuits.htm but what is this Connector unit ?? how i can connect everything, this diagram dont tell me nothing icon_sad.gif I know for electrician is not a problem but i do electric to, but i not professional, and i realy want learn for future icon_smile.gif So i very please about diagram and about connection solutions, when i do this how someone connect oven ??
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 382 times
PostPosted: Wed Aug 17, 2011 9:46 pm Reply with quote
TROLL ALERT
Back to top
 Alert Moderators
EFLImpudence
from United Kingdom
Thanked: 1249 times
PostPosted: Wed Aug 17, 2011 10:16 pm Reply with quote
ricicle wrote:
TROLL ALERT
Could you be more specific?
Back to top
 Alert Moderators
ericmark
from United Kingdom
Thanked: 738 times
PostPosted: Wed Aug 17, 2011 11:51 pm Reply with quote
Click do make a double connection unit which will allow two outlets it of course does need a back box it looks like this however to ask simple questions like you have asked shows you are not really able to do the work. Electrics is not a join the dots exercise.
We have to for example when selecting cable first look at the installation method. 6mm sq cable could be rated anywhere between 23.5 amp and 58 amp according to installation method and type of cable.
Assuming you want a 32 amp supply with Reference Method 103# (in a stud wall with thermal insulation with cable not touching the inner wall surface) and thermoplastic insulated and sheathed flat cable you would need 10mm sq.
If you want a 45A supply even 16 mm sq cable is not big enough for Method 103#.
Of course you may be using Reference Method 100# (above a plasterboard ceiling covered by thermal insulation not exceeding 100 mm in thickness) in which case 32A can be drawn from a 6mm sq cable.
Think you need to get some one to do this for you and ask them why they are doing it the way they are doing it and not DIY until you know a lot more.
Considering it will likely cost more to DIY then get a registered electrician to do the work by time you include LABC and hire charges it seems a little pointless to DIY a kitchen.
Back to top
The following user says thank you to ericmark for this useful post:
danyboy (18 Aug 2011)
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1966 times
PostPosted: Thu Aug 18, 2011 7:17 am Reply with quote
Well you shouldn't - you are incompetent.
That's not the problem - your incompetence is.
Excellent idea.
But while you are learning, please get an electrician in. I seriously doubt that you could put forward a convincing case that you could do the work in compliance with the Building Regulations anyway, so it would be illegal for you to even try.
Back to top
The following user says thank you to ban-all-sheds for this useful post:
 Alert Moderators
danyboy
from United Kingdom
PostPosted: Thu Aug 18, 2011 7:09 pm Reply with quote
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
FHT floor heating control - mystery wiring diagram!! 7 2260 Sun Jun 01, 2008 9:48 am
solar shed project !! wiring diagram 33 860 Sat Aug 23, 2014 7:41 am
Help! Changing tridonic ballast but wiring diagram different 3 100 Mon Nov 11, 2013 8:23 pm
Wiring diagram correct for 63A RCCB and 50A MCB? 8 7040 Fri Dec 04, 2009 4:27 pm
Wiring diagram 6 1000 Mon Jun 25, 2007 6:30 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
