DIYnot
Local | Network
   DIYnot > Forums
Local | Network
What the hell IS that noise - Yaris 2006
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
kuytd
from United Kingdom
Thanked: 1 time
PostPosted: Tue Aug 23, 2011 2:01 pm Reply with quote
I have a creak in the suspension, sometimes worse than others. Left hand side, when on tight, or full lock.
Had it some time ago when car had warranty, Toyota kept changing top mounts that seemed to cure it for short times, but its still there.
What could it be??....
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2625 times
PostPosted: Tue Aug 23, 2011 2:09 pm Reply with quote
Driveshafts can knock on full lock when they are worn, but in your case it could easily be the top strut bearing....thats the bit that turns with the spring as you steer round a corner.
I always replace these when I do springs - most of them are totally clapped out.
Back to top
 Alert Moderators
kuytd
from United Kingdom
Thanked: 1 time
PostPosted: Tue Aug 23, 2011 3:31 pm Reply with quote
I see, makes sense. But do you think this would be the case considering this has happened since the car was 18 - 24 months old?
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2625 times
PostPosted: Tue Aug 23, 2011 4:43 pm Reply with quote
No, of course not - depending of course, that Toyota actually did change the top mount, rather than just stripping it out and putting it back together again!
I'm sure every other Yaris doesn't make a noise!
Back to top
 Alert Moderators
kuytd
from United Kingdom
Thanked: 1 time
PostPosted: Tue Aug 23, 2011 6:19 pm Reply with quote
Well, story was one toyota garage fitted it, creak returned, next garage found the first had fitted one part of it upside down! So original garage had to do it again, but creak returns...
Back to top
 Alert Moderators
Peter.N.
from United Kingdom
Thanked: 221 times
PostPosted: Wed Aug 24, 2011 11:55 am Reply with quote
Does it do it when driving in the rain? if not or its quieter it will probably be a rubber bush somewhere in the suspension - assuming it uses rubber bushes.
Peter
Back to top
 Alert Moderators
kuytd
from United Kingdom
Thanked: 1 time
PostPosted: Wed Aug 24, 2011 6:18 pm Reply with quote
I have not noticed the noise going in the rain. It happens so often that I try to ignore it. Should be wet the next couple of days, so will listen out for it...
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
Sparkplug Hell!!!! 5 540 Sat Sep 29, 2007 6:45 am
Mondeo MK3 Handbrake Hell!! 6 240 Sun Dec 07, 2014 11:55 pm
Yaris engine block drain bolt. 3 160 Tue Jan 10, 2012 6:12 pm
Dead/Flat battery Toyota Yaris + Portable chargers 16 340 Tue Apr 28, 2015 8:45 am
toyota yaris: water in boot? 2 120 Mon Nov 28, 2011 8:54 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
