i've got an indesit wg1234t washing machine on which the fabric conditioner tray stays full of water at the end of cycle- Is this normal?
I do not use any conditioner as i use a two in one powder.
If you go to http://www.indesit.com/indesit/enter.do
and follow a contact us.
You can then ask the question & get the answer from the horse.
I did similar with Service.
Good Luck
this is usually caused because the syphon tube is blocked , remove drawer and clean thouroughly paying particular attention to the syphon tube and the channel that leads off the syphon tube on the underside of the drawer .
