bathroom fan wiring
30 Aug 2005
Glasgow
Hi, I am having difficulty fitting a bathroom extractor fan. There is wiring already in place for it, which consists of a red, blue, yellow and what appears to be a bare copper wire. The new fan requires a permanent live (L), neutral (N)and switch live (L1). Can anyone advise what goes where please? Cheers.
You can't be too sure about these things, becuase there is no set in stone way of doing this, but that said, I've never seen, or heard anyone choose to differ from the following:
Blue - neutral
Red - Live
Yellow = Switched live
EDIT: Bare copper wire is the earth, and should be sleeved with earth sleeving and terminated in a terminal block in the absense of any desinated termianal for it
EDIT2: Now got an EDIT label :oops:
And don't forget that thing that 'appears to be a bare copper wire' - That is the Earth and needs to be attached too......
(Adam's edited his with a more detailed description of what to do with it now)
Sorry, normally put a notice in that I've editted something, forgot this time, struck me after posting I shouldn't assumed the what to do with the earth was known (no offence to the OP btw)
Why not use your multimeter to identify which conductor is which?
If you don't have one, then either get one or stop messing with your electrics.
Hey guys, thanks for you help, it was much appreciated. I hope I can repay the favour if you ever have any computer/IT problems
Cheers
you may want to look in for refernce there is a drawing that shows how its done
Cheers
what problems could you solve?
______________________________
moderator
this post has now been split, the questions are now here
where is the reference stuff its sounds great but cant find it
