DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Worcester Bosch Greenstar 35i Boiler making jet noise.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
aliasojo
from United Kingdom
PostPosted: Wed Sep 07, 2005 6:51 am Reply with quote
I hope someone might be able to offer a suggestion as to what the problem is with my condensing combi-boiler.
The boiler is nearly 2 years old and approximately 9 months after it was installed it started making a noise when a hot tap was turned on. The noise only lasted for a couple of seconds before stopping and was only really a slight annoyance so we just left it.
From then until now though, the noise has increased in loudness and also length of time it lasts for. So much so that we can't turn on a hot tap at night, otherwise it would wake the whole house. It's a hard noise to describe, but it sounds kinda like a plane taking off. No gurgling, just a whooshy noise.
It never happens when the rads heat up, only when a hot tap is turned on.
The green pressure gauge on the front of the boiler shows the needle is in the right area.
I'll need to get someone out, but I don't want to be ripped off just because I'm female and it looks like I don't know anything about boilers. (Which I obviously don't, lol.) Be grateful if anyone has any ideas?
Back to top
 Alert Moderators
Gasman1015
from United Kingdom
PostPosted: Wed Sep 07, 2005 8:18 am Reply with quote
Call the manufacturers service department if you believe the noise is from the boiler and not the pipe work.
It may still be under warranty.
Back to top
 Alert Moderators
aliasojo
from United Kingdom
PostPosted: Wed Sep 07, 2005 9:00 am Reply with quote
Thanks for reply. The boiler does have a 2 year warranty, but was never serviced after the first year so I think that invalidates the warranty?
That's why I was a little concerned at what the problem might be as I expect I'll need to pay for it and I can't afford to to take the risk that a tradesman could tell me allsorts and I'd be none the wiser, if you know what I mean.
I'm happy to pay for a good job done, I'm just really worried about getting conned. It wouldn't be the first time.
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 64 times
PostPosted: Wed Sep 07, 2005 11:16 am Reply with quote
How can they tell on a greenstar?, just tell em it has. It probably just needs an adjustment to the air / gas mixture but this can only be done with professional equipment.
Back to top
 Alert Moderators
aliasojo
from United Kingdom
PostPosted: Wed Sep 07, 2005 11:45 am Reply with quote
I was assuming I'd have to have had some sort of stamp like on a car service book to confirm or an invoice or something as proof?
Bit scared to tell them it's been serviced if I get backed into a corner and I look daft when I can't produce proof. What if they asked me the name of the company that serviced it? icon_confused.gif
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Wed Sep 07, 2005 12:05 pm Reply with quote
if they dont ask keep stuhm
pretend your one of the wise monkeys
if all else fails use old faithfull "dont know my hubby sort's that sort of thing out" icon_wink.gif
Back to top
 Alert Moderators
jiminblack
from United Kingdom
Thanked: 175 times
PostPosted: Wed Sep 07, 2005 2:50 pm Reply with quote
If it's making a hooting noise it'll be the CO2 levels that need setting up. Call up Worcester. Tell them you've had it serviced by others and take it from there. They can only say sod off!
By the way if you have to pay for a Worcester service it's 98.00 and a breakdown is 175.00. CO2 should be checked on a service...see where I'm coming from?
Back to top
 Alert Moderators
aliasojo
from United Kingdom
PostPosted: Thu Sep 08, 2005 8:17 am Reply with quote
Thanks again everyone. See your point about the service Jim icon_biggrin.gif
And in case a MOD is reading this.......apologies for resurrecting an old thread yesterday. I skim read the regs and missed that one. icon_redface.gif
Back to top
 Alert Moderators
COG
from United Kingdom
Thanked: 1 time
PostPosted: Thu Sep 08, 2005 5:50 pm Reply with quote
As said the greenstar needs the corect co2 settings and if out the boiler can Hoot. Dont wory about the service just call Worcester the service eng wont be too botherd about no proof of service but if its been noisy since new then you poss have low gas inlet pressure you require at least 17mb working at max to get the co2 ok.
Back to top
 Alert Moderators
dg123
from United Kingdom
PostPosted: Fri Sep 09, 2005 12:37 pm Reply with quote
We had the same problem with the 35 HE+ (probably the same boiler). Phoned W-B, an engineer was there the next day. He set the CO2 levels to the correct settings and we have not had the noise since - about 6 weeks now. There was no charge for the work or parts as was within the warranty period. Phone them before the 24 months expire.
Back to top
 Alert Moderators
deviantslice
from United Kingdom
PostPosted: Sat Sep 10, 2005 10:05 pm Reply with quote
Could also be a blocked DHW heat exchanger.
Back to top
 Alert Moderators
sid2411
from United Kingdom
PostPosted: Tue Apr 17, 2012 8:08 am Reply with quote
Hi guys bit new to this so sorry to jump in on a forum but having similar probs with greenstar oil combi. Started not doing the hot water and pump making loud whining noise. Been told prob diverter valve but not sure.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3522 times
PostPosted: Tue Apr 17, 2012 8:21 am Reply with quote
You have added to a seven year old thread about a different boiler model.
Start your own thread and we will ask you all the usual about how do you expect it to work when you dont have it regularly serviced.
Tony
Back to top
 Alert Moderators
sid2411
from United Kingdom
PostPosted: Tue Apr 17, 2012 6:04 pm Reply with quote
oops sorry,
As I said, new to this.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Worcester Bosch 42CDi - Making Loud Noises When Firing Up 3 80 Thu Oct 31, 2013 12:24 pm
jaguar 24 combi boiler making noise 3 80 Wed Mar 09, 2011 2:43 pm
Boiler making noise only while on gravity feed 4 280 Sun Nov 09, 2008 9:40 am
hot water cutting out and boiler making rattle noise 2 80 Thu Feb 24, 2011 7:03 am
combi boiler making strange noise 9 1340 Thu Feb 10, 2005 8:41 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
