DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
radiator pipes
This topic originated from the How to page called Replacing a radiator
Click here to return to the page called Replacing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
bricktop2
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 12, 2005 12:02 pm    Post Subject:
radiator pipes
Reply with quote Thanks
Hi
i want to put a new radiator in my kitchen and would like to put the pipes in the wall, its a red brick internal wall. Can i just plaster over them or do i need to wrap them in something?
Thanks in advance
Wayne
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
penpusher
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 12, 2005 12:51 pm    Post Subject:
I know it's a lot of work but if you're using microbore (8mm or 10mm),
the best way is to channel out the wall for plastic wire trunking (the white plastic stuff used to hide electrical cables) and run the pipes in that. It protects the copper pipes from corrosive elements in the plaster and it just makes a better job of it.
If not then yes you must wrap the pipes, again to prevent corrosion from the plaster.
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Mon Sep 12, 2005 1:53 pm    Post Subject:
Plaster doesn't attack copper, unlike cement. But if plaster gets hot it will crack, and if pipes are held tightly they will move and crack whatever's holding them, or any joints.
Back to top
 Alert Moderators
bricktop2
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 12, 2005 2:54 pm    Post Subject:
Thanks guys, i will get some of the plastic trunking and use that icon_biggrin.gif
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Plumbing Towel radiator - chasing pipes 10 720 Tue Jan 10, 2006 7:58 am
One Cold Radiator + Pipes 3 80 Tue Oct 27, 2009 4:58 pm
Cool radiator and noisy pipes 2 740 Fri Feb 25, 2005 11:05 pm
Radiator has both pipes on one side? 4 500 Fri Feb 23, 2007 10:45 am
up and down radiator pipes 7 480 Thu Aug 24, 2006 8:30 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
