DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Electrics to Garage
This topic originated from the How to page called Routing cable
Click here to return to the page called Routing cable.
Goto page 1, 2  Next
  View previous topic :: View next topic
Author Message
dbx
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 20, 2005 9:57 pm    Post Subject:
Electrics to Garage
Reply with quote Thanks
Hi All
Been in my house for 3 years and although I've never had any issues, the previous owners have run electrics to the outside garage and I need to know if its ok or not.
Its 2.5mm T&E on a 32a MCB from the CU which also has a 80a RCD fitted, then into some flexible conduit (looks like stuff from wickes) which is buried under a block drive for about 6m then surfaces in the garage and is split by a junction box to the lights and to a 13amp fused spur which supplies the mains.
Is it ok or should I pull the plug??
db
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
notb665
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 20, 2005 10:47 pm    Post Subject:
Junction box? (Not the best thing). Maybe you mean switchfuse unit, or a mini-CU? Any chance of a picture?
In any case the lights should be on 6A fused spur.
__________________
I may not be a lady, but I'm all woman.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Tue Sep 20, 2005 11:34 pm    Post Subject:
Or a 5 or 3A if you can't find a 6A cartridge fuse. icon_twisted.gif icon_twisted.gif
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Wed Sep 21, 2005 8:05 am    Post Subject:
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Wed Sep 21, 2005 10:04 am    Post Subject:
ok potential major issues with your setup (some of which have already been mentioned.
1: 32A is too high for a single run of 2.5mm T&E (is your CU a type that its still easy to get breakers for? post a pic if unsure).
2: The lights should be fused down as mentioned above
3: just what is this conduit like, it really needs to incorporate a metal layer and that metal layer needs to be earthed if you are using it to run T&E underground.
btw how is the block drive layed? if the block are just layed in sand you can probablly lift them without destroying them if you need to redo the supply to the garage.
Back to top
 Alert Moderators
dbx
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 21, 2005 6:59 pm    Post Subject:
Electrics to Garage
Thanks for the quick replies.
I've done some digging around and found out that there are 2 cables in the conduit from the CU a 2.5mm and a 1.5mm.
The mains is on its own 32A MCB and the other is on the same lighting circuit as the kitchen (2x60w) and external light (100w).
The cables enter the garage then go into 2 junctions one for the lights with no other fuses and the mains one goes to a 13A switched spur.
Some pictures are at:
http://www.dbeevers.v21hosting.co.uk/electrics/cu.JPG
http://www.dbeevers.v21hosting.co.uk/electrics/trunk.JPG
http://www.dbeevers.v21hosting.co.uk/electrics/switch.JPG
http://www.dbeevers.v21hosting.co.uk/electrics/junc.JPG
thanks
db
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Wed Sep 21, 2005 7:36 pm    Post Subject:
Re: Electrics to Garage
As plug said - 32A is too high a rating for 2.5mm˛ T/E....
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
chrislangham
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 23, 2005 11:54 am    Post Subject:
Dear db,
Did you test your work after you finished it?
What readings did you get?
Is the system therefore safe?
Chris
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Fri Sep 23, 2005 12:17 pm    Post Subject:
Chris - what work do you think dbx has done?
__________________
Back to top
 Alert Moderators
chrislangham
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 25, 2005 2:38 pm    Post Subject:
I am asking
Back to top
 Alert Moderators
dbx
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 26, 2005 7:40 pm    Post Subject:
hi
Thanks for all your replies have been away and just got back.
No testing but the work was in when we bought the house.
I've never had any problems with shorts or fuseing.
dbx
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Sep 27, 2005 8:19 am    Post Subject:
chrislangham wrote:
I am asking
No you're not - you asked him:
chrislangham wrote:
Dear db,
So I'll ask you again - please read dbx's original post, and tell us what work he has done that he would need to test?
__________________
Back to top
 Alert Moderators
netsidedeveloper
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 03, 2005 7:07 pm    Post Subject:
Can anyone explain why a 32A MCB is not suitable for 2.5mm T/E when the majority of domestic ring mains and radial circuits use it ?
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Mon Oct 03, 2005 7:17 pm    Post Subject:
ring mains have 5mm˛ cable icon_wink.gif - there are 2 cables supplying every socket
Back to top
 Alert Moderators
netsidedeveloper
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 04, 2005 8:55 am    Post Subject:
Thanks...
Back to top
 Alert Moderators
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Garage electrics 5 260 Fri Feb 15, 2008 8:38 am
dismantling prefab garage - also it has got electrics - help 3 260 Fri Jun 06, 2008 4:17 pm
Extended electrics in the garage 9 720 Sun Aug 12, 2007 3:52 pm
garage electrics hmmm? 12 560 Tue Mar 11, 2008 8:21 pm
Extending basic garage electrics 3 560 Thu Aug 04, 2005 9:37 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
