DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
What to consider when laying laminate flooring for 1st time?
This topic originated from the How to page called Wooden flooring
Click here to return to the page called Wooden flooring.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
matthaddon
from United Kingdom
Thanked: 0 times
PostPosted: Sun Oct 09, 2005 11:53 am    Post Subject:
Reply with quote Thanks
Hi everyone.
I am considering having a go at laying laminate flooring (probably wooden laminate) for the first time in my hall way and dining room (same flooring all the way through both rooms) and wondered if anyone could give me some tips please?
It is a 1930's house, so I have a bay window and fire place in the dining room, and the stairs in the hall to negotiate.
Also as the original skirting is on and we have had all the walls replastered before we moved in so I am not planning to remove them to lay the flooring.
The things I am concerned about are:
1. How much flooring should I buy? i.e. how much over the measured size of 21.25 sq. metres?
2. What kind of underlay is best to use over the existing floorboards (dining room) and wood flooring (hall)?
3. Where abouts should I start laying the flooring? i.e. hall (strairs side or flat wall) or dining room (fire place side or flat wall)
4. What is the best option for edging the flooring up to the skirting boards
5. Do I need to leave a set gap for seasonal expansion etc?
Any other advice on things to consider or be aware of would be greatly appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Sun Oct 09, 2005 1:19 pm    Post Subject:
Re: What to consider when laying laminate flooring for 1st t
Hi Matthanddon
wood laminate is better called Wood-Engineered, to prevent confusion with the 'plastic' Melamine laminated flooring icon_wink.gif
1) rule of thumb: add 5 - 7% extra for saw-waste, then calculate that up to the next full pack
2) if all underfloors are reasonably level 2 - 3 foam underlayment is fine. don't put any combine products (which included a DPM) down
3) what you think would be the easiest and straightest wall
4) we use flat (solid) beading, this is pinned to the floor and covers the expansion gap.
5) rule of thumb: wood-engineered minimum of 10mm (on all sides); solids: 3mm per linear meter width. e.g. room 4 meters wide = minimum of 12mm
We also recommend using thresholds in doorways, even when you plan to install the same flooring in connecting rooms: some rooms have a different climate and could react different to humidity and temperature (e.g. hallways versus living room with central heating on). A threshold also enables you to keep the expansion gap everywhere.
Have fun
__________________
You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA.
Back to top
 Alert Moderators
confused 2
from United Kingdom
Thanked: 0 times
PostPosted: Sun Oct 09, 2005 8:18 pm    Post Subject:
Hi WoodYuoLike, did you really mean you pin the flat bead to the "floor", surely it should be to the skirting so the floor can move freely under the bead
Back to top
 Alert Moderators
confused 2
from United Kingdom
Thanked: 0 times
Back to top
 Alert Moderators
HandyJon
from United Kingdom
Thanked: 0 times
PostPosted: Sun Oct 09, 2005 8:19 pm    Post Subject:
3) Also you generally start from the left.
Another point is that you want to try and have the boards in line with the window or light source. In other words the short edge of the board is parallel with the light source. This minimises any shadows. This also is the case in long hallways.
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Mon Oct 10, 2005 11:01 am    Post Subject:
It very hard to pin a 5mm flat beading to the skirting icon_wink.gif I think you confuse it with scotia.
No, it's correct, pin the beading to the wooden floor (thin pin). If there is any movement, but with wood-engineered you wont have that much movement, the beading will move with the floor (also a 'warning system' for movement).
We have been using flat beading for years and more and more U.K. suppliers stock it because of the increase in demand, so we don't have to get in from NL any longer.
__________________
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Mon Oct 10, 2005 11:03 am    Post Subject:
Depends on the way the T&G is constructed, cause there isn't really an universal standard. Sometimes it's not possible to start from the left
__________________
Back to top
 Alert Moderators
HOASAMU
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 10, 2005 11:40 am    Post Subject:
EASY WAY TO LAY LAMINATE
HI
If the laminate you are laying down , is the click and fix stuff
try my easy way to lay it
instead of following the instruction which say lay one board at a time and connect both the front and side of each plank as you go (spent many hours clicking getting one end of the line to click in for the other to pop out )
i found it easier to connect one whole line boards together first
then line them up to previous line of boards
click them in so the whole line is pointing up at the desired click in angle
referr to the instructions for this
then take your shoes off and slowly walk down the line of boards
slowly pushin them down and clicking them in place as you go
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Mon Oct 10, 2005 11:45 am    Post Subject:
Ignoring instructions from manufacturers can result in losing the guarantee, just as long as are are aware of this.
__________________
Back to top
 Alert Moderators
HandyJon
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 12, 2005 10:32 pm    Post Subject:
A bit of an extreme statement! Worse that can happen with click style laminate is that some of the boards get their T&G damaged a bit. You quickly learn to try something else. I've even installed some laminate flooring by sliding it along the long T&G when there hasn't been much space to fit it the normal method.
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Thu Oct 13, 2005 9:06 am    Post Subject:
Sorry, but it's not extreem, it's reality I'm afraid.
__________________
Back to top
 Alert Moderators
matthaddon
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 13, 2005 11:56 am    Post Subject:
Thanks for all the advice folks, I am starting to get a bit more confident about having a go at laying the flooring myself.
We have seen a couple of styles of the Kahrs 'Wood Engineered' flooring (thanks Woodyoulike icon_wink.gif ) we like, does anyone have any experience (good or bad) of laying this flooring.
Also how hard wearing is it?
Thanks again for taking the time to respond and help out a novice!!! icon_biggrin.gif
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Thu Oct 13, 2005 12:41 pm    Post Subject:
Kars is as good as any other well known brand (Karelia, Takett, Haro etc, etc), nowadays there is hardly any quality difference between them. We have lots of experiences with various Wood-Engineered brands, mostly good (only bad experience we had was when one of our suppliers had changed his range to the 'cheaper' range: typical 'banana-shaped' boards, which are a pain to install properly without gaps).
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Time frame of laying parquet 4 4500 Wed May 17, 2006 1:40 pm
Screed floor drying time before laying oak floor 4 2480 Wed Apr 27, 2005 11:02 am
Drying/curing time for screed 3 960 Mon Dec 18, 2006 2:10 pm
first time for everything 5 640 Fri Aug 04, 2006 9:39 pm
First time with levelling compound 3 11140 Sun Nov 21, 2004 7:50 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
