DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Curtain Poles on UPVC
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
brenton
from United Kingdom
PostPosted: Tue Oct 18, 2005 7:07 am Reply with quote
I have UPVC window frames with very wide UPVC trim frames extending to the ceiling.
Therefore in order to put up curtain poles I will have to drill throught the UPVC surround in order to fix the curtain poles through the UPVC to the wall behind.
What type of drill bit is best on UPVC? Is this the right way to do it and any tips?
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 216 times
PostPosted: Tue Oct 18, 2005 7:29 am Reply with quote
You need to know if behind the upvc there is a firm fixing. You can drill the upvc with HSS drill bit
Back to top
 Alert Moderators
brenton
from United Kingdom
PostPosted: Tue Oct 18, 2005 8:11 am Reply with quote
There is firm fixing behind UPVC but there is a good 10mm gap as this is just surround trim (whatever the right phrase is) rather than the actual window frame. So curtain pole screws have to go through UPVC, through 10mm of air and then into wall behind.
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 216 times
PostPosted: Wed Oct 19, 2005 8:46 am Reply with quote
Ok so you will get a firm fixing the problem will be, when you tighten the screw you will deform the upvc, you really need a sleeve between the wall & the upvc.
You could try & fix it see what it looks like (I dont think it will look very good). The only sugestion I have is to perhaps put a sleeve behind the upvc.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
No bay-poles...options? 2 80 Fri Sep 27, 2013 10:35 am
where can I get bay window poles 4 100 Fri Oct 14, 2011 9:29 pm
How to attach curtain rail / track / pole to UPVC door ? 7 2440 Sat Dec 24, 2011 12:18 pm
nowhere to fit a curtain rail 3 100 Wed Mar 19, 2014 2:54 pm
Max load for 2 brackets (curtain pole) 5 100 Sun Aug 03, 2014 7:21 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
