DIYnot
Local | Network
   DIYnot > Forums
Local | Network
One pump ... two showers
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
lawk
from United Kingdom
PostPosted: Mon Sep 22, 2003 10:25 am Reply with quote
we have a power shower in the bathroom,
what we are planning on doing is to have a power shower in a en-suite.
would it be possible to run both showers from the same pump as long no one uses the showers at the same time.
or would it be better just installing another shower pump.
any advise would be much appreciated
Kin
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Mon Sep 22, 2003 10:28 am Reply with quote
i am not a plumber or heating engineer, but i would have thought two pumps would be easier / better, since if one fails the other will still work
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 46 times
PostPosted: Mon Sep 22, 2003 6:54 pm Reply with quote
I am a plumber and heating engineer icon_wink.gif and think that breezers advice is spot on
Back to top
 Alert Moderators
lambo
from United Kingdom
PostPosted: Sat Sep 27, 2003 2:54 pm Reply with quote
I have the system that you have and there is no reason why two showers can't be driven by one pump. Pressure will drop if both used at the same time, but this is probably rare. When the pump breaks, you can replace it. No need to have twice as much equipment as you need, it's just creating extra work. But listen to the advice of professionals, and then make your own decision. Most pump manufacturers will not guarantee a pump supplying two showers - but then its in their interest to sell pumps.
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1099 times
PostPosted: Sun Sep 28, 2003 11:16 am Reply with quote
There's no "wrong " or "right" on this one I think. With 2 pumps both working away you'll empty your hot water (and possibly your cold) pdq though! Sharing a pump, both showers will "probably" still work.
You might consider a "whole house" pump - then all your hot and cold gets pumped. Generally better quality, often quieter and longer lasting, though more expensive. Talk to Stuart Turner.
Bear in mind that most pumps seem to leak eventually! If there's room, chop the bottom off a F&E tank and put in in that, with an overflow pipe connected to outside. Garden hose will do. Might save you a ceiling sometime.
Pad Stones (as used under lintels ) are brill for resting pumps on. Very dense.
Back to top
 Alert Moderators
Scoby_Beasley
from United Kingdom
Thanked: 50 times
PostPosted: Sun Sep 28, 2003 2:00 pm Reply with quote
When I worked in Ireland I knew a Pad(dy) Stones. Big fella and solid as a rock icon_wink.gif icon_biggrin.gif icon_biggrin.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
is there a maximum pump bar pressure for showers?? 2 460 Mon Aug 28, 2006 12:40 pm
SHOWER PUMP REQUIRED TO RUN TWO SHOWERS ? 2 580 Thu Sep 15, 2005 11:59 am
two showers off one pump 5 360 Sun Oct 11, 2009 3:33 pm
2 Power showers 1 pump 4 2560 Tue Feb 15, 2005 6:21 pm
Triton 2.2 Bar pump running 2 showers 15 1100 Tue Mar 11, 2008 9:06 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
