DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Bleeding Radiators on a gravity hot water system
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  Bookmark and Share View previous topic :: View next topic
Author Message
Backdraft436
from United States of America
Thanked: 0 times
PostPosted: Fri Nov 11, 2005 12:51 pm    Post Subject:
Reply with quote Thanks
When the heating system does not have a circulation pump how do you bleed the radiators? The heater is located in the basement and all the radiators are located on the first floor. The heater make is "Royal".
Thank you.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 4 times
PostPosted: Sat Nov 12, 2005 1:52 am    Post Subject:
The venting process is no different without a pump, because it should be done without a pump running anyway.
Can you locate the vent plug on each radiator? If so, that's really all you need to know. I would also take the precaution of making sure that the feed and expansion cistern is not empty or low.
Back to top
 Alert Moderators
Backdraft436
Thanked: 0 times
PostPosted: Mon Nov 14, 2005 12:47 pm    Post Subject:
Softus, thanks for the reply.
I have located the vent plug on the radiators. They are opened using a small key.
The water pipe which connects to the heating pipe is closed. There is an expansion tank which is empty with a relief valve off to the side located next to and above the heater between the floor joist.
There is no "feed cistern".
When I open the bleed valve on the radiators, some air comes out but no water. Does the water valve which connects to the heating pipes need to be open in order to "top off" the radiators?
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 4 times
PostPosted: Mon Nov 14, 2005 10:13 pm    Post Subject:
OK - so do you have a combi system?
If so, then you should have a filling loop with a pressure guage.
If air stops coming out of the rad vent, then check the pressure and repressurise if necessary.
When all rads are done and all vents closed, repressurise again to the minimum of the range specificed by the boiler manufacturer. Then check the pressure when hot and make sure it's less than the maximum.
Does this answer the question?
Back to top
 Alert Moderators
Gasman1015
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 14, 2005 10:19 pm    Post Subject:
Feed and expansion cistern is the same thing, and fills the system.
Relief valve is probably air vent.
You need water.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Gravity hot water bleeding 2 520 Sun Oct 29, 2006 10:36 am
Gravity fed problems. Hot water on only - Radiators hot 11 720 Sun Mar 04, 2007 10:04 pm
Gravity fed boiler warms radiators first. 20 760 Sun Nov 20, 2005 1:13 pm
Bleeding radiators, air releasing but not water??? 4 440 Mon Jul 02, 2007 4:00 pm
adding a pump to gravity hot water system 2 260 Mon Apr 19, 2010 3:42 pm
Varme Carbon Heating Film 20.0sqm & 30sqm Depron Varme Carbon Heating Film 20.0sqm & 30sqm Depron£697.71Varme Carbon Heating Film 13.0sqm & 20sqm Depron
Varme Carbon Heating Film 13.0sqm & 20sqm Depron£478.29
Varme Carbon Heating Film 6.0sqm & 10sqm Depron Varme Carbon Heating Film 6.0sqm & 10sqm Depron£258.84Varme Carbon Heating Film 15.0sqm & 20sqm Depron
Varme Carbon Heating Film 15.0sqm & 20sqm Depron£530.04
Varme Carbon Heating Film 22.0sqm & 30sqm Depron Varme Carbon Heating Film 22.0sqm & 30sqm Depron£749.46
£0.00
DIYnot
