Hello
My boiler switches on for a while and then switches off. There is a device that looks like a pump which seems to have the job of splitting the output of the boiler between hot water and central heating. This device is vibrating and seems to be working but its inlet pipe is hot but both outlet pipes are cold. I suspect that it is jammed. Will bleeding the radiators help? If I add chemicals to the system to dissolve any gunk will I be able to flush the system by myself or is it a job best left to professionals? Many thanks.
