I\\\'ve just had a glowworm 30 cxi installed and i\\\'ve found that the CH does not appear to be getting as warm as maybe it should.
The temp reading on the front of the boiler is 73c at its maximum setting. According to the handbook the max temp should be around 84c.
I currently have (i think) 22mm pipes running from the front of the house to the back where the boiler is. Is it possible that this could be the cause of the problem?
That said, the temp on the readout does not seem to drop when the fire is on or when the HW is running.
many thanks
many thanks
