vokera syntesi 25 error code 08 burner overheat
22 Nov 2005
Yorkshire
My boiler is coming up with 08 error code - which is a burner overheat I reset the boiler and all seems fine then it happens later on. This seems to have happened since with weather has got colder & I have turned up the tempreture
It may be due to dirt in the system if it was not powerflushed when the boiler was installed.
Turning the temperature setting down may reduce the number of trips.
Tony Glazier
