dcook
Joined: 28 Nov 2005 Posts: 2 Location: Cleveland, United Kingdom Thanked: 0 times
Posted: Mon Nov 28, 2005 9:42 pm Post Subject: internal door into gargae |
I wish to put a door from the kitchen into the garage. The wall is not load-bearing and i realise that i need a fire resistant door. How long does it need to fire-proof for and is there any other building regs i need to worry about.
I know i should get local approval, but they seem to want plans and visits which would cost over £400 - this does not seem reasonable for simply fitting a door. How long has this regulation been in place and what problems may i encounter if i just did it and kept quiet?
cheers |
chappers
Joined: 27 Aug 2004 Posts: 994 Location: United Kingdom Thanked: 0 times
Posted: Mon Nov 28, 2005 11:27 pm Post Subject: |
it needs to be 1/2 hr and you need a step down into the garage of 100mmm your BCO is being a bit tight if he is insisting on you submitting drawings you should be able to do this under a buildings notice. |
dcook
Posted: Tue Nov 29, 2005 3:48 pm Post Subject: what info do i need to summit for this |
Re: the buildings notice,
what info do i need to summit for this and is there normally a cost involved?
cheers |
