Zanussi FJS1225W - does complete wash cycle, but not the fas
3 Dec 2005
Berwickshire
Hello folks. My machine does the full wash cycle ok, but not the final fast spin, instead it just rotates at the standard wash speed. Following some research on the web, I've tried looking at the pressure switches and blowing in the tubes (back into the drum) just to make sure the pressure tubes were clear, no change here. Also tested the machine by going into engineer mode (switching the machine on while pressing the Start & Skip buttons simultaneously - another gem from the net). In this mode every machine function worked perfectly, including 250rpm spin test and max speed spin test.
I’m trying to decide whether I should pay to get it repaired, or just scrap it and get a new one? (I’m fairly technically competent so will have a go at any basic suggestions)
Any advice would be greatly appreciated! Thanks in advance …
