- Joined
- 5 Dec 2005
- Messages
- 3
- Reaction score
- 0
- Country
Have a Potterton Suprima 40 which has worked fine for 5 years. The system has cold water storage in roof along with expansion tank - both OK. 2 motorised valves (water/heating) in airing cupboard with Grundfos pump - all OK.
When boiler fires up, everything is OK for about 30 mins. Hot water fine, all radiators heat up but boiler cuts out well before room stat temperature is reached and pump stops.
When boiler cuts out, there is a great rumbling and banging/gurgling from both the boiler area (not sure quite where but maybe the flu) and around the pump pipework.
The boiler can be re-started but the pump does not cut in and the boiler cuts out again within a couple of minutes - with the same banging, rumbling and gurgling.
Leave the system for about an hour, fire it up and the sequence starts over again.
Have thought of pump (but that is obviously working at least initially) and airlock (but all the rads are warming up - no cold spots and hot water is fine) can't get to the bottom of it. Any help or ideas would be great.
Best regards,
Best regards,
