Two Lights Two Red/Reds @ the switch
5 Dec 2005
Help! I'm replacing a 1xdimmer and 2xbulb lights with 1xdimmer and 2xhalogen arrays. I got as far as replaing the bulb lights and every thing works ok. I went to replace the dimmer and lost track of what connected to where. Incoming to the dimmer switch are two Red/Reds (earthed). I can only get one light to light up. Can you help?
How many wires all together at the dimmer and what colours. What are the connections on the back of the dimmer.
ban-all-sheds said:
And how have you connected them?
If I connect one of the pairs (only) to L1 - C the one light (but not the other) works perfectly on the Dimmer. If I swap cables, nothing works.
You only have one permanent live. Use your multimeter to identify it.
You also need to look at the wiring of the light that doesn't work, because you've got a cable going there with only one core in use - what's been done with the unused one? Any trial and error to get the light going might be a bad idea if you don't know where it goes..
I've proven TWO permanent lives - but still no joy -could I have blown the halogen unit.
Ah - my mistake -
I thought that meant you had only one cable with permanent live.
So two cables, A & B.
Both cables have a permanent live.
If cable A is connected to C & L1, light A works, and light B does not.
If cable B is connected to C & L1, no lights work.
Have you double checked the connections at light B? What happens at B if you temporarily connect the local permanent live to it?
ban-all-sheds said:
Ah - my mistake -
Thats my next step - I'll try connecting a simple bulb back onto light B and see what happens. If not I'll do as you say - thanks. I take it this form of wiring is unusual?
OK - so heres some progress.
On Light B there's a RED/RED (one to loop and one to Live) and RED/BLACK (RED to loop and Black to N) - both earthed.
If I connect a standad bulb between L and N no joy. If I connect between L and E or L and Loop we have light.
Do you think the N return through Light A may be at fault?
PROBLEM SOLVED - LOOSE NEUTRAL AT LAMP A!!
