DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Sealing and painting breeze blocks - interior garage wall
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Author Message
JonHead34
from United Kingdom
PostPosted: Mon Dec 19, 2005 11:59 am Reply with quote
Hello all
I'm a novice DIYer and want to paint the interior of my garage direcly onto the breeze blocks. I was just wondering what you would recommend as a sealer/primer before applying the paint and what paint would be best to use? The advice I've been given so far is to use watered down PVA as sealant and a standard masonry paint, but I was given that advice by someone not much more experienced than me! Would I be best off using an exterior masonry paint? I ask this because even though I'm painting the interior of the garage, the other side of the blocks are outside and open to the elements.
Many thanks for reading my post and for any advice you may be able to offer!
Merry Christmas
Jon
Back to top
 Alert Moderators
Zampa
from United Kingdom
Thanked: 26 times
PostPosted: Mon Dec 19, 2005 10:28 pm Reply with quote
Forget the PVA...you can use anything on concrete blocks..masonry pint is ok, but if its inside it doesnt matter anyway.
Contract matt is ok as is vinyl matt..id go for contract as its only a garage and your not likely to be washing the walls down.
Be prepared to give it three coats though....thin the first by around 30% to let it soak into the surface....then thin the next two by about 20%...to help it go on easier.
Back to top
 Alert Moderators
harrowbuilder
from United Kingdom
PostPosted: Mon Dec 19, 2005 10:36 pm Reply with quote
Id be tempted to seal the outside first. Any masonry sealant will do, B + q do a value one which works well and is cheap. your concrete blocks and are porous and as im sure its a single wall, damp will penetrate if you dont seal the outside first.
Back to top
 Alert Moderators
JonHead34
from United Kingdom
PostPosted: Tue Dec 20, 2005 9:48 pm Reply with quote
Thanks fo the replies guys.
Actually harrowbuilder it is not a single wall - there is another layer of standard red housebricks on the outside and the breezeblocks inside - my original post was misleading, sorry. It is the interior of the breezeblocks that I want to paint. I guess with the protection of the outer layer of housebricks, I'm best to proceed as suggested by zampa. From what you have said, I guess there would be very little to gain by adding a sealant before painting in this situation?
Many thanks
Jon
Back to top
 Alert Moderators
Zampa
from United Kingdom
Thanked: 26 times
PostPosted: Tue Dec 20, 2005 10:54 pm Reply with quote
NO need to seal inside.....seal from what??..
You say 'breeze blocks'....do you mean concrete blocks?...a lot of people get the two muddled,, actually i dont think 'breeze blocks' exist as such these days...they are now the light thermalite blocks?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
Painting on Breeze Blocks and Bricks - advice needed please 3 440 Thu May 12, 2011 7:43 pm
Painting breeze blocks 3 4380 Thu Jun 22, 2006 8:11 am
painting breeze blocks 8 6340 Fri May 05, 2006 9:55 pm
Breeze Block Outline Appears Through Painted Wall 5 360 Sat Mar 21, 2015 2:46 pm
PAINTING Breeze and Brick 3 1000 Tue May 29, 2007 10:28 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
