- Joined
- 6 Jan 2006
- Messages
- 13
- Reaction score
- 0
- Country
I have searched the whole site but can not find an answer. I want to wire in a 3kw single fan oven, a 5.8kw ceramic hob and an extractor hood which uses 150-250watt all from the 6mm cable from consumer unit and passes through the dp cooker switch. is this possible? my idea is to run the 6mm from cons unit to cooker switch then 6mm to a junction box and from there feed 6mm to hob, 2.5mm to fcu then to oven and another 2.5 to another fcu onto extractor! can anyone tell me if this sounds ok? and if its not ok how can you get all three so they can be isolated at the cooker switch. Thanks for any help in advance!!
