Joined: 08 Jan 2006 Posts: 4 Location: Birmingham, United Kingdom Thanked: 0 times
Posted: Sun Jan 08, 2006 8:44 pm Post Subject:
Extending a plug
I am putting in a false wall and my existing double plug will be behind the wall. I want to extend the plug to the outside of the new wall so can i simply extend some 2.5mm twin and earth from the old plug and connect to another replacement plug on the new wall. The old plug will remain behind the wall but will not be used.
Is this classed as a spur as the original plug wont be used.? Does this comply with regulations as surveyors cant get to the ring main?
Joined: 18 Jul 2004 Posts: 5166 Location: Devon, United Kingdom Thanked: 20 times
Posted: Sun Jan 08, 2006 9:06 pm Post Subject:
No - this isn't acceptable.
As you are installing a new wall, it wont hurt if you damage the original wall?
I would knick the plaster off to gain some cable (hopefully the cables come downwards). You can then put your new plug a little higher up on the new wall.
You may also find, if your cables have been run in conduit, that you can pull a little more through.
If none of these ways seem appropriate, a crimpt joint is the only way forward - this must be enclosed in a suitable enclosure, and you should crimp both cables seperately to give you two new cables at the new socket.
Posted: Sun Jan 08, 2006 9:31 pm Post Subject:
Thanks for the reply. After several conversations I have decided to get myself an electrician in. Let him sort it. This way i know its certified.
How much does it cost to rewire about 4-5 double plugs and install a cooker plug?. I already have a fuse on my board for it.
______________________
lynda. moderator. please note rule 9
Joined: 16 Mar 2004 Posts: 5066 Location: United Kingdom Thanked: 0 times
Posted: Mon Jan 09, 2006 11:41 am Post Subject:
Tekkishodan wrote:
sarcasm is the lowest form of wit.
I was looking for a ballpark figure from an electrician.
It will depend on how difficult the job is due to access, so it would be hard to give a figure but i'd roughly say about £30-£40 per point plus materials
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
