Built in oven connection
7 Feb 2006
Kent
Hi there, Just found this forum and it looks good.
I am about to refit my Kitchen and want to install a built in Oven. My old free standing Cooker was supplied from the CU via a 30amp fuse through a 30 amp cable. I have wired this size cable in anticipation of needing that ammount of supply for the new cooker.
I have not chosen the Oven yet but have noticed that a lot of them are able to run on a 13 amp plug. My question is, if I decide to buy one of these can I run it from the existing wiring that I have prepared if I use a lower rated fuse in the CU. I cant really begin the refit as the Oven tower has to be the first unit in.
Thanks in advance for any suggestions.
you can either keep same fuse and use fcu at cooker, or plug and socket, or change fuse and hard wire in. over rated cable is better than underrated
Are you planning to get a gas hob? If not, an electric hob will need your high-amperage cooker supply. Hobs use more power than ovens and will not run off a plug.
Hi Andy,
Thank you for the information. I have bought a 2Kw oven and wondered if I should change the 30amp fuse to a lower rated one and run 2,5 cable from the CU directly to the oven. I was hoping to also run a double plug next to the housing for a couple of small appliances. could I run another cable from the same fuse in the CU.
hiccup said:
Hi Andy,
You haven't told us what sort of hob you intend to fit. For the oven, it will be much easier to run a spur from an existing socket in the kitchen.
But you could do it how you describe, just leave the chunky cable in place, and use it to feed your socket, in case it is needed for its intended use again in future. Leave the 30A fuse in place, and protect the oven locally with a 13A fuse, either in an FCU or in the plug top. This leaves you with the scope to add sockets if you like.
