Bosch won\\\'t drain or Spin, Have fitted new pump but still
Status
Not open for further replies.
9 Feb 2006
Birmingham
while my Bosch Maxx WFL 2260 was coming close to end of cycle all lights on the front came on and the machine would not go any futher with the drum full of water, it would not drain or spin but would start working if it was put back onto a normal cycle, I fully drained it down manually but it still would not spin or drain so I replaced the pump with a new one but the problem still persists, it will go through a whole wash cycle perfectly until it reaches the drain part then it comes to a halt again with the drum full of water and the END cycle light flashing, I have checked for any filter or pipes blocked but everything seems very clear......please please Help!!!
using a big font does not get you a faster / better reply
Hi Breezer,
please excuse my ignorance at using a Big Front, seeing as it was the first time of using this forum I did not now it was against the rules, the option was there and I was absolutely desperate so I used it to simply show my desperation I really didn't think for one second that it would be an issue or I would actually have a complaint about it.
May I ask what your position is in this Forum, are you one of the Moderators.
Regards
Lazman42
It's not against the rules, just doesn't help with replies?
People read a thread and reply if they know the answer, doesn't matter if the thread is the size of a bill board!
Hi Macimini,
you have hit the nail on the head!!
"People read a thread and reply if they know the answer, doesn't matter if the thread is the size of a bill board!"
So if what you say is correct why feel the need to mention it in the first place if it doesn't matter???, Breezer......just being a bit petty I think!
Hi, my Whirlpool is doing the same thing. I noticed that nobody answered your question but I'm wondering if you've solved the problem yet. I could use any advice. Thanks, Brandy
Hi Brandy,
since I had no reply from this forum, I had to find out what the problem was myself through elimination, firstly I purchased a new drainage pump but that didn't fix it, then I thought it might even be the main motor so I had it tested but that was fine, in the end it turned out to be the mainboard which would have cost around 130, so seeing as the machine was over 5 years old we decided to cut are loses and ended up buying a new machine.
Regards
__________________
locked to stop hi jacking
Status
