potterton profile 30
11 Feb 2006
Surrey
I have a problem with this boiler in that it wont ignite or spark, the fan works as does the pressure switch. If I take the front cover off and let the fan run for a while then put the cover back on and do this a few times it will ignite and run perfectly well until the timer switches it off then I have to repeat the process over again, does anyone have any ideas??
thanks in advance
with the case off and the boiler fires up could be a few things!The aps could be at fault or the aps tubes blocked or cracked.Is the heatexchanger clean and all the flue ways clear?
Hi I have replaced the aps and made sure the tubes are clear and not split, I've cleaned the flue ways and the heatexchanger is clear, only thing is when the boiler is running it doesn't seem to be pumping anything out of the flue, ie when its been cold in the morning I should see warm gas/air/moisture being pumped out shouldn't I? I am beginning to think it could be either the pcb or gas valve pilot soleniod
Are you sure the inner flue pipe is not corroded through somewhere along its length?
Have you proved the APS/Flue/Fan/Venturi?
Believe it or not but I once found a bird in the flue of one of these boilers.
Is this one of these boilers with a positive pressure fan?
If so are the case seals in bad condition. If they are it may explain your prob.
Positive case pressure yes, which makes it a potentialy lethal boiler.
ghostspider you clearly don't know what you're doing and could get yourself into grief, apart from expensive bills. Call a corgi in!
