I'm installing a heated towel rail in the bathroom, which is plumbed into the central heating, but also has an electric heating element for use when the central heating is off.
I'm planning on wiring the element into a switched fused spur, mounted at the bottom of the bathroom wall. I'd be most grateful for answers to the following.
1. Is the plan as above permissable from a safety / bathroom 'zones' perspective? The planned site for the spur is adjacent to the towel rail and basin (v small bathroom!)
2. Does it matter that the spur is switched? I need some way of switching the element on and off, so can this be on the spur, or does it have to be outside the bathroom?
3. Would there be any way of incorporating a timing device into the circuit? For example, it would be good to be able to time it to turn off once I've gone to work.
4. I have a shower pump, supplied via an RCD. Can I/should I supply the spur via this RCD, or should be only be supplying the shower pump.
Many thanks in advance for answers to some/all of the above.
