- Joined
- 17 Nov 2003
- Messages
- 8
- Reaction score
- 0
- Country
Hi. First time here AND a novice so will try to be succinct. Most rads in house working fine on both floors (ground and first). Except three on the first floor only heating partially at the bottom. The rads in question have two valves one at each end, a spindle like projection if you take the cap off. Do I unscrew the nut at the base of this spindle like valve to bleed the rads? Do I turn the valve at the other end of the rad off whilst I do this? Or have I got it (completely) wrong?
