The simple answer is that there is a lot of pipe, full of cold water, which has to come out of your tap before the hot water from the tank or combi boiler reaches your sink.
Many thanks i didn't know that, There is no way you can run it through quicker then. It is a combi boiler, its in the garage not far away, the setting on the boiler is set to 4 is that ok what does this mean.
