DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
plugs
This topic originated from the How to page called Wiring a plug
Click here to return to the page called Wiring a plug.
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Electrics UK
  View previous topic :: View next topic
Author Message
skunny man
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 24, 2003 5:44 pm    Post Subject:
plugs
Reply with quote Thanks
hi man i took a tube light down from the loft and put it in my room but it had no plug on the end and the wire colors are red, black and a copper wire(no casing) what wire goes where!!!???
i don't want 2 blow up my light so could you help???? icon_confused.gif icon_confused.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Mon Nov 24, 2003 5:58 pm    Post Subject:
I personally wouldnt do that (too late) because in my opinion flourescent lights are too bright for your average room "man"
but since you have where do you want to put it? on the ceiling (replacing your existing light or just on a plug ? that said they are "cool" icon_cool.gif if you put a u.v. (black light in them)
First thing you should do is put connector block where you took the light from (saves hassle later)
if you want to plug in your light do as follows
Get a length of 3 core flex and connect it into the light as follows
brown= L
Blue = N
Green / yellow = earth
at the plug end
Brown to the right
green/ yellow to the top
blue to the right
and put a 3 amp (red) fuse in the plug
If you want to change your existing ceiling / wall light do as follows
brown= L
Blue = N
put spacers under the light (so as not to crush the flex) fix light to joists in ceiling
undo ceiling rose
remove old lamp fitting
Blue to the two balcks (where the blue from existing light was)
Brown to the single black (where the brown for the existing light was)
green / yellow to the green (or green yellow) wires in the rose
this way is easier than taking the whole rose down since if you change your mind it is much easier to change it back / something else
and do as my signature says
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
sam k
from United Kingdom
Thanked: 0 times
PostPosted: Fri Apr 01, 2005 9:32 pm    Post Subject:
Re: plugs
yea mate the coppere 1 iz the earth it iz not ment to have aney sleving on because you have 2 put it on your self go to an electrical shop and ask for earth seleving
__________________________
moderator
sam k welcome to the forums but the post you replied you is nearly 2 years old please see 17
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Electrics UK All times are GMT
Page 1 of 1
Jump to:
Kitchen Plugs ? 3 540 Sun Jan 07, 2007 2:40 pm
European Plugs 11 820 Sat Mar 24, 2007 6:49 pm
Plugs, fuses and ratings 9 760 Thu Oct 12, 2006 3:48 pm
13 Amp Plugs/Ring Circuits 14 1020 Thu Aug 31, 2006 11:14 am
plugs 2 480 Wed May 17, 2006 11:14 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
