DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Continuity
This topic originated from the How to page called Installing a power socket
Click here to return to the page called Installing a power socket.
  View previous topic :: View next topic
Author Message
sotonblue
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 07, 2006 2:58 pm    Post Subject:
Continuity
Reply with quote Thanks
I have removed a socket and checked the cables for continuity. I have continuity between red and red, but also between red and black. Is this right??
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Tue Mar 07, 2006 3:05 pm    Post Subject:
It is a ring circuit, then?
If you have an appliance plugged in and switched on, at another socket or an FCU, then it will be providing a path between the P and N. Unplug them all and try agan. Do you know the resistance between the red and black?
p.s. in answer to your question "no"
Back to top
 Alert Moderators
sotonblue
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 07, 2006 3:12 pm    Post Subject:
I don't know the resistance as i only have a continuity tester.
It is a ring circuit.
Does this mean that if anything is plugged into any other plug socket in the house then i will get continuity between red and black??
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Tue Mar 07, 2006 3:18 pm    Post Subject:
If it is something simple like a lamp, a kettle, or a heater, then, yes. They work by connecting a piece of (resistance) wire between the P&N. It gets hot by the current passing through it (you knew that, didn't you? Or are you the guy with a cannabis plantation in his loft?).
You will have someone along in a minute saying you should check the resistance in the ring, and betwen P&N, and to earth.
But if you are searching, e.g. for a cut or disconnected point in a ring, a continuity test is a start.
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Tue Mar 07, 2006 5:59 pm    Post Subject:
test between black and black, red and red, earth and earth. if all three give continuity, you have a ring. ideally, you should be measuring resistance too, as you can have continuity but high resistance (as your red-black continuity is probably showing)
As said, unplug everything, turn off all switches, FCUs, and try again.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Mar 07, 2006 6:06 pm    Post Subject:
Re: Continuity
Why did you measure between red & black?
What did you think you would find, and why?
What did you think the reading would tell you?
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Continuity Test Results 5 440 Mon Jan 28, 2008 4:31 pm
no continuity on live? 20 660 Thu Feb 14, 2008 12:24 pm
continuity earth and live but not tripping board 3 560 Sat Nov 17, 2007 8:20 pm
Ring Final Continuity 5 420 Tue Oct 23, 2007 12:00 am
strange end to end continuity ring main readings 3 480 Wed Aug 22, 2007 9:41 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
