Joined: 09 Mar 2006 Posts: 5 Location: Glasgow, United Kingdom Thanked: 0 times
Posted: Thu Mar 09, 2006 11:46 am Post Subject:
Loft Socket
Hi All,
I would like to install a socket in my loft. Can I split a socket cable which is running across my loft and fit a junction box or socket to it ? The new socket is for a single light only.
Any advice would be greatly appreciated.
Agags-Groove
Joined: 02 Jun 2005 Posts: 10887 Location: Cumbria, United Kingdom Thanked: 39 times
Posted: Thu Mar 09, 2006 12:07 pm Post Subject:
Re: Loft Socket
Agags-Groove wrote:
Hi All,
Agags-Groove
As long as it is not part of a spur from a ring main it is OK to do it like this, just make sure any new cable is the same size as the original. Please note junction boxes should be accessable for inspection. I take it by this you are just going to plug the light in?
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Thu Mar 09, 2006 12:10 pm Post Subject:
A lot of houses don't have socket cables in their lofts. How does there come to be one in yours? Is it feeding a socket already, on a spur or as part of a ring? This affects whether you can do what you describe.
However, you say you only want to fit a lamp to it. All lofts have plenty of lighting circuit cables in them, would you be happy to add an extra lamp on there?
Posted: Thu Mar 09, 2006 12:15 pm Post Subject:
The light will be plugged in , but i would consider a switched Fcu (?) if thats ok. My main concern is how to determine if the t & e in my loft is ok to split. Like you said about it not being part of a spur. How can i tell the difference between a spur and the ring main cable ?
Posted: Thu Mar 09, 2006 12:19 pm Post Subject:
John,
A good point ! I assumed the cables were for sockets ! I think i might be getting out of my depth trying to wire a light from a lighting cable , or are can you just add a spur/light to them ? havn't got a clue !!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
