Hi Everyone,Hope you might be able to help.I have a Jaguar 23kw Boiler about 4 years old.Over the last week or so it has started making a weird grrrrr/buzzing/fast ticking noise....pretty hard to describe a noise!! It is also accompanied with a light vibration which you can feel if you touch the casing or even the pipes at the bottom.Everything still seems to function ok,ie radiators still hot and hot water fine.At first I thought it was the pump so I took that off and checked it for any obvious wear,the impeller spun freely and did not seem worn at all.Although it did have some movement along it's shaft,it could be pulled out about 10mm and pushed back,is this normal?Anyway I put that back and still the noise was there.I then checked the flue fan but again that was fine and seemed to spin very freely.I also live in a very soft water area so I don't think it will be scale,I read this can clog everything up!!The noise is worse with the just central heating on,especially after about 20 minutes or so,although you can also hear it slighty with just the hot water on and it also seems to get slightly quieter if you switch the hot water on with the central heating on(does that make sense!!).The worst noise still seems to come from the pump,towards the back.Oh forgot to mention but the pump seems to take longer to stop after boiler is closed down.Well hope I have explained it ok and would really appreciate any advice/help,Many Thanks,Cheers Carl
