I am wiring a Vent Axia VA150T kitchen fan (with timer) from a lighting circuit via a 13amp double pole isolating switch.
The fan terminals have a LS live switch terminal.
The wiring diagram shows the fan wired from a ceiling rose via a 3 pole isolator switch with the LS terminal connected to the switched live terminal in the rose.
I don't want the fan switched from the light switch so why can't I just wire from the lighting circuit without wiring the LS terminal?
