greg1962
Joined: 03 Apr 2006 Posts: 2 Location: Belfast, United Kingdom Thanked: 0 times
Posted: Mon Apr 03, 2006 1:09 pm Post Subject: Reinstating door/s in an internal archway |
We're in the process of buying a house but there is an internal archway between the dining room & kitchen that we would like to close with a glass panel door or double doors. Unfortuneately the width and height of the arch i think will cause a problem, it's 43" wide & 85" high but with the curve of the archstarting before the height of the door therefore it's not square. Anybody any ideas on what i can do? Thanks. Greg |
Scrit
Joined: 21 Dec 2005 Posts: 1094 Location: Lancashire, United Kingdom Thanked: 0 times
Posted: Mon Apr 03, 2006 4:45 pm Post Subject: |
Sounds like you'll need to make a frame with an arched head to match the brickwork. That or make a frame where the top is arched and the bottom flat.
Scrit __________________ Measure twice, cut once - except fingers! |
joe-90
Joined: 28 Oct 2005 Posts: 10199 Location: United Kingdom Thanked: 57 times
Posted: Mon Apr 03, 2006 8:26 pm Post Subject: |
Knock on the arch section with your fist. If it is hollow it is just a mesh arch.
Knock it out until you have a large rectangular door and build a new frame to suit new doors. Don't try to work around anything that you don't have to.
joe |
Scrit
Posted: Mon Apr 03, 2006 8:48 pm Post Subject: |
Awe Joe, you're no fun! Arched head work is fun to do and looks sooooo nice. Really. But OK, if it's a false un' then probably a better approach.
greg1962
Posted: Tue Apr 04, 2006 3:59 pm Post Subject: |
Thanks for the advice so far lads, very helpful. I can't get back into the house again for a while to test if its false or not but i'll try it as soon as i gain access. I like the easy option if possible.
Thanks |
