| Author |
Message |
craig1
Joined: 14 Sep 2005 Posts: 160 Location: United Kingdom
Posted: Fri Apr 14, 2006 12:11 pm |
Hello,
Been looking at installing some spot lights in the kitchen.
Also buying some hole saws for this job and for
future DIY jobs. Does the cut out for the spots have to be the exact
size as stated on the lighting instructions as most hole saws dont
match the required size.
cheers. |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
mw3ybx
Joined: 14 Apr 2006 Posts: 3 Location: Pembrokeshire, United Kingdom
Posted: Fri Apr 14, 2006 12:25 pm |
Hi Craig
This all depends on the depth of the rim of the spot light. Some lights have deep rims so the hole does not have to be spot on, but within mm .. Electrical wholesalers will have the right size holesaw for the job.
Dan |
| Back to top |
craig1
Posted: Sat Apr 15, 2006 5:39 pm |
Cheers!
Thanks for the info Dan. |
| Back to top |
Porker
Joined: 28 Oct 2003 Posts: 230 Location: United Kingdom
Posted: Sat Apr 15, 2006 8:58 pm |
Just a tip. Cut a hole in an old piece of plasterboard before you try to fit your lights just to check. I've just fitted some that wanted a 68mm holesaw. Can't find one so used a 64mm and had to notch out for the clip brackets with a stanley knife. |
| Back to top |
RF Lighting
Joined: 31 Mar 2006 Posts: 16125 Location: Leeds, United Kingdom Thanked: 717 times
Posted: Sat Apr 15, 2006 9:54 pm |
If your ceiling is lath and plaster make sure you take it very steady when drilling the holes, as it is very easy to remove great chunks of plaster without even trying.
Also don't forget Part P of the building regs requires this work to be notified to LABC
Rob |
| Back to top |
Pens
Joined: 17 Jan 2006 Posts: 2437 Location: Kent, United Kingdom Thanked: 2 times
Posted: Sat Apr 15, 2006 10:34 pm |
| Back to top |
Jim2287
Joined: 22 Oct 2005 Posts: 226 Location: United Kingdom
Posted: Sat Apr 15, 2006 10:35 pm |
we use those, but its seems a bit expensive for a diyer who is only going to use it "one off"
cheaper to get out a compass and cut a hole with a pad saw ( bought for as little as £1 or maybe less ) |
| Back to top |
Pens
Posted: Sat Apr 15, 2006 11:12 pm |
| Jim2287 wrote: | we use those, but its seems a bit expensive for a diyer who is only going to use it "one off"
Of course you do, so do most people who want a perfect hole
1/2 the problem with diy projects is the tools used. You know how hard it is even with practice to cut a small round hole in plastered plasterboard.
My advise - save the money on labour - spend some of it on pro tools then you've got 1/2 a chance of a pro looking job |
| Back to top |
Jim2287
Posted: Sat Apr 15, 2006 11:29 pm |
hehe true
not that hard to cut circle with pad saw ... but if you cant do it straight away then its a time waster to practice, like u said |
| Back to top |
PartyCan
Joined: 15 Mar 2006 Posts: 43 Location: Staffordshire, United Kingdom
Posted: Sun Apr 16, 2006 3:13 am |
Got my cutters from a place called CAROLS chaps where i live only payed 2.99 for it and it cuts all sizes of holes, it fits in the end of your drill.
I cut mine with the next size down and just went round the hole with a round file so that the downlights was a tight fit in the hole.
It doss a nice round hole as well but where somert on your eyes before you do the cutting because of the plaster getting in your eyes. |
| Back to top |
viewer
Joined: 02 Apr 2005 Posts: 532 Location: United Kingdom Thanked: 30 times
Posted: Sun Apr 16, 2006 5:47 pm |
The Maplins set of holecutters is 4-99 and is great for cutting plasterboard and softwood. I've used them for SELV 12 v & GU10 perfect sizes included. Great. Better than the more expensive ones I've had for years and which stay in the box. |
| Back to top |
