DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Gaisborough Diplomat shower - pressure problem
This topic originated from the How to page called Planning a shower
Click here to return to the page called Planning a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
st1100paneuro
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 25, 2006 9:29 pm    Post Subject:
Reply with quote Thanks
I have just fitted a gainsborough diplomat power shower in my bathroom. I took the feed from the hot and cold bath tap supplies (the cold feeds off of the loft tank which is a 50 gallon tank on a raised box area in the Loft).
the installation instructions said to take the feed from the tank supply.
The shower runs really well but if both my kids take a shower one after the other (one does like to soak a bit) then the shower has a tendancy to run out of water and stops. the Hot supply is fed from the immmersion tank on the landing (same level as the bathroom) but the actual hot water is supplied via the boiler in the garage whihc heats both the water and the central heating.
I have looked in the tank and the only thing I can see that looks a possible problem is that the cold feed to the tank appears to be furred up and although the water runs through it does not have the same sort of pressure that i get from the downstairs kitchen cold tap.
Have I made an error in the installation or is it something else?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
diyatbandQ
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 21, 2006 7:38 pm    Post Subject:
out of hot water
1. put the other kid in first and then the one that likes to soak a bit will run out and save you a lot of money.
2. The feed pipes should come directly from the tank (hot and cold)
3. Does your hot tank take hot water directly from the boiler or indirectly through an internal coil from the boiler?
4. How big is the hot tank?
Back to top
 Alert Moderators
st1100paneuro
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 21, 2006 8:56 pm    Post Subject:
1, I have done that and he complains!!
2, I have taken the feed pipes from the Bath tap supplies Which appear to come from the tanks.
3, I haven't got a clue the boiler is in the garage and fed to the immersion tank on the landing. which then feeds the rest of the house.
4, The immersion tank is fairly big but I am not sure as to the capacity.
I have changed the furred up feed valve to the cold tank in the loft and discovered that the switch appeared to have seized up (allowing the takn to feed ver slowly) it now appears to fill much quicker and touch wood I have had no trouble since!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
output for a Gainsborough Diplomat Power Shower Transformer 2 300 Thu May 14, 2009 10:15 am
Diplomat cooker - faulty gas rings 3 180 Sat Jul 11, 2009 6:16 pm
Shower/washing machine - water pressure problem? 2 340 Sun Jan 07, 2007 12:55 pm
yet another shower problem-pressure equalizing valve? 4 640 Sun Aug 14, 2005 2:35 pm
Potterton Puma 100 problem and pressure for shower 5 600 Sun Dec 04, 2005 11:48 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
