I moved into a new development about Sept 04, the house was fitted with a Vokera boiler. From the very start I have had nothing but bother with it. The main issue is that it flashes a 01 code. There appears to be no pattern to this as it can be brought about by using the heating or simply running a shower. The 01 can occur seconds after the boiler ignites or an hour or so after the heating has come on. As the boiler is currently under guarantee I have had their engineer out on numerous occasions. He has tried placing various parts but 2 years later he still has not cracked the issue. The last time he was out the insisted that it was due to the following: Shower, water type, flue, and air flow around the boiler. As the error code occurs when I use the central heating it cannot be the show. I have the same water type as my neighbours so it can not be that, the flue is angled to prevent rain fall and seems fine, the boiler was not always in a cupboard and had plenty of air circulating around it when I first moved in so it can not be that.
Any advice would be much appreciated.
Redniall
Redniall
